Should be $499 MAX!!!!What will happen when the 4080Ti comes out? Everyone will start moaning about the price... etc!
I didn't, I 'downgraded'will say they need DLSS3 in their life and upgrade.
I wouldn't wait. Life is short, we might not even live to see 4080Ti which we don't even know in how many months it's coming. Just get what makes sense to you now and don't wait more than few days at most - it won't make you any happier. Also, i wouldn't buy anything for "future proofing" as it's been proven many times over the years that vendors will just come up with new tech next generation that will make current gen unsupported and will then push Devs to use it heavily in games, so you feel compelled to upgrade anyway. But each to their own.Hi,
I'm in real need of a new rig... and I'm at the time of my life where I want to go relatively BIG. Not 4090 big... i'm still human, but I was considering the 4080.
However, everywhere I read it sounds like it's known to be 'a bad deal' even though it seems to be a great card. Lots of advice seems to say "Wait for the 4080Ti". But what does that actually mean for me?
I'm a total noob with this stuff and in complete analysis paralysis at the moment. Would hate to let my impatience result in buyer's regret.
- Does it mean that when the 4080Ti comes out, it will be a better card for the same price? (surely it will still cost more)
- Does it mean that the 4080 (regular) will reduce in price? (so I can then get a bit more affordability)
- Does it mean that I should just skip the 4080 and the Ti version, and just save for a 4090, switch to AMD, or drop down to a different card?
Thanks everyone!
and retailers shelves will have to be reinforcedWhat will happen?
The 4080ti will come out, and it will be expensive.
Do you do anything that specifically benefits from an nvidia card (like workstation apps or VR), or do you only game?
Just gaming for me
From the sounds of things, I should go for a cheaper card.... was thinking the 7900XT which still sounds like overkill but it seems to be cheaper than last gen cards (what the hell is going on?).
Also by not having 12GB vram or less, they are not obsolete from Day 1.The 7900 XT right now is probably the best value card available.
20gb ram
rasterization perf not fair off a 4080
ray tracing perf not far off a 4070ti
At £750 it makes the 4080 and 4070 look expensive (not hard i know)
I wouldn't trade my 4070 for any radeon even if it had 100gb vram.its features and software support are years behind geforce.
Ok.....
RT Ultra setting 4070TI is indeed be faster, but it's not the kind of frame rate that most serious gamers would consider ideal anyway (less than solid 60fps), so most of them would be playing the game with with RT at Medium setting instead which the 7900XT would be around the same performance as the 4070ti.I wouldn't trade my 4070 for any radeon even if it had 100gb vram.its features and software support are years behind geforce.
Ok.....
This is getting surprisingly spicy! But on the topic... I have heard about Nvidia having cool software stuff like DLSS which Radeon doesn't (and there was some other software solution that like doubled your frame rate... can't remember the name). Is that a real consideration for a 1080p person like me? Or just for uber fidelity kings?
