Gigabyte Motherboards have a back door in their BIOS
I didn't expect them to remove the option as it's a feature needed for auto updates for those that do use it, just keep the setting off in the BIOS. I'm not sure short of the average user, who would actually use it since the accepted method is to manually update the BIOS so you know exactly what is being done and can oversee the process etc.
"6th through to 11th gen affected"
Good thing I stuck with 12th gen from day 0 :p
The heat issues impact 13th and 14th gen too, good thing I stuck with 12th gen since then :D
