Can’t find any ports to plug in old hard drives
6 Jul 2023
uk
I have a couple of hard drives with all my old computer videos/ games/ edits etc
Saved on it. I really need to get them onto my new pc but can’t find any ways to connect them. I can connect to the sata cable but nothing else. I can’t find any way to connect it to give it power annoyingly.
I had old machines made at overclockers and they came with a bundle of spare wires inside the machine. This one hasn’t for some annoying reason.
Is this a common thing with new computers from overclockers?
Do you not have anything bundled with the PC? No boxes? If you have a modular PSU, they might be wrapped up somewhere.
What's the case? They could also be cable tied behind the motherboard, between the panel and the tray.
I cut lose all the wires behind the motherboard and everything seems to be used unfortunately.
Is there a way to upload photos straight from
My phone without needing a social media site
You can use a free file upload site to temporarily store photos or amazon if you have a prime account and you dont mind them data mining them.
You can get 4 pin plugs to sata connectors
My basket at OcUK:
Total: £4.88 (includes delivery: £3.99)​
If you have an old psu you could always 'jump start it' and just use it to power the hard drives.
My basket at OcUK:
My basket at OcUK:
I have one of these but can’t find a place to
Plug it in at all‍♂️
Take a picture of the insides of your PC and upload it on here
In that first picture I see a 4 pin white Molex connector hanging out the front of the case? Where does that go to? It looks like it goes in and up to the fans?
If you literally have no connectors spare then you need to buy a cable which basically plugs into one of your molexes, extends it so that it keeps on going, but also spurs out a new connector as well. Like this 1 to 2 extender:
Or, just buy an external 3.5 inch hard disk drive caddy which you hook your hard disk up to inside and then plugs into your PC via USB.
That was just one I had from my old computer I was just putting it in my pc hoping for a fit.
I should have taken a pic without it in there sorry.
Do you still have your old PC? If so, link the two with an ethernet cable via your internet router, fire it up, and copy over the files over the network.
External enclosure (usb) 3.5". Should be able to get one for £20-£30
It’s just damn annoying I spent all this money on a new computer and it’s the first one I have ever gotten that didn’t come with extra wires for hard drive transfers
So it's lack of power connectors that are the issue?
I've actually just paid out for something like this which is actually a cheaper option than an enclosure (and has capability to access 2.5" sata and even old IDE drives, which is why I have bought one)
AGPTEK USB 3.0 to IDE/SATA Converter​
I might annoyingly have to do that. I needed it working for today as I had some
Editing job deadlines now im kinda screwed
So is it just a lack of a spare sata power connector? You could just swap out one of the used sata power. From the pictures it looks like one might be powering an rgd or fan controller. You try one of those and just live without lights for a little while
