- 22 Nov 2020
Will the reference GRE version be available in the UK?
Yep pricing is all over the place - looks like 7800XT and everything below needs a slight price cut, otherwise why wouldn't you get a 7900GRE rather than a 7800XT
AMD direct- haven’t seen a listing.Already is
From AMD?
Ah ok. That was way overpriced I recall.From a competitor site that I can't mention.
Not anymore
Ah yeah, not bad pricing. Nitro looks good
..awaits overclocking results from new owners of 7900 GRE.Slight regret about buying a 7800XT mba for £499 in October. I’ve overclocked it so I’m sure I’ve bridged the 8-10% perf differential between the GRE.
GRE enjoyers will probably have similar feelings when the top SKU RDNA4 launches later this year if the pricing and performance speculation is accurate and on it goes!
88c hotspot is not that bad unless the fans are running full tilt, then I would consider it a slight problem due to the temp and a bigger problem due to the noise.88 Degrees C hotspot apparently, these things need a good cooler.
Maybe 88 is fine - I honestly don't know?
I'm pretty sure someone is gonna figure out a way to unlock overclocking if enough of these enter the wild...awaits overclocking results from new owners of 7900 GRE.![]()
Just looking at the reviews and see the nitro hotspot is around 81 - 82 is this high ?, seems lower than the others on techspot.OC usually stock the Nitro's. Hotspot temp seems high on the GRE nitro but if it's anything like my 7800xt nitro, the fan curve is incredibly chilled out & with a small bump it's much better, still effectively silent.
