Caporegime
- 13 May 2003
- Warwickshire
Hi all
Just starting on the next project in my room-by-room renovation.
I've started gutting the room and the window sill was very out of level and wobbly, so I removed it (and have retained it) and found...
There was a lot of loose plaster, which I have removed (or will remove).
Any recommendations as to the best way to sort out the sill please, i.e. install it correctly and make it level? Is best practice using wooden packers and screwing into them, gripfill, expanding foam, bonding plaster, other?
The whole room will be replastered with bonding where required for larger holes.
Thanks.
Thanks.
