New build time - VR development and data science rig.
16 Mar 2024
Lancaster
New parts:-
Threadripper 7960x cpu
Asus Pro WS TRX50-SAGE WIFI mobo
128gb 5600 Kingston FURY Renegade Pro DDR5 RDIMM Memory
Powercolour 7900xtx Helhound graphics card (will be watercooled with Alphacool block.
Lian Li O11D EVO XL - Black
EK Water Blocks EK-Quantum Kinetic FLT 360 D5/DDC Body D-RGB Reservoir - Plexi
2x EK Water Blocks EK-Quantum Surface P420M Triple Fan Radiator - Black - 420mm
Will be reusing these parts from my current build TR 3960x/6900xt:-
3x M.2 drives (Kingston FURY Renegade 2TB (boot), Samsung980 PRO 2TB (games), Samsung 970 EVO Plus 1TB (scratch))
2x 2tb Seagate HDDs
D5 Vario pump
EK Vardar 2200rpm fans
Corsair 1600AXi psu
Liyama G-Master GB3461WQSU 34"monitor plus random 24 inch side monitor.
I'll be using softline tubing and I don't like hardlines.
I'll post more pics as more parts come in and when I start the build (hopefully next weekend.
Case/rads/fans/res has arrived at my mum and dads!
Also bought the front mesh panel so will be mounting 3x140 intake in the front. The case will be sitting sideways on a shelf above my monitor so the front glass panel would be a little redundant anyway and as it's also in an alcove there's no real line of sight on the front.
Nope - already have a roll of transparent XSPC 16/11 I'm going to use - reusing all my old fittings as well (XSPC black chrome compressions and rotaries etc)
Do you need the mesh panel (temp-wise)?
Looks incredible as-is!
You know, after testing I don't need the mesh panel - temps are great. I didn't realise I would be able to fit two intake fans behind the res so that handles air intake. I'll pop the mesh panel on ebay :)
I'll post another pic update next week once I've sorted the block rgb and added more coolant. Removed the corner brace as well - looks amazing!
