Pretty sure I'm decided on a 65" TCL mini-LED, but can't decide between their two latest versions.
Help me choose:
www.tcl.com
Or
www.tcl.com
Input from PC (I'll be upgrading my trusty 2080Ti to either a 3090Ti/4080 or 7900XTX, depending on Black Friday deals), PS5, Switch & Firestick 4k Max...
I think the 805K is the newest screen, as reviews are scarce and release details are dated a fortnight ago, but the 845K has plenty of fair reviews and is 2000 Nits peak brightness, compared to the 1300 of the 805K...
Study is painted in Denim Drift, so it's not an overly bright room - I suffer from chronic cluster headaches and migraines after a TBI, so having somewhere dark I can escape to is important.
I also have custom shutters to fit in the window recess, which will allow me to completely block out the light, plus a daybed/sofabed going opposite the media wall.
Excuse the temporary shelving - that's so I can get stuff off the floor and measure how much I need to trim all the network cables - they'll be going into conduit in the corner, then painted. The POE Switch is mounted low on the wall and will be hidden by a cabinet.
Feature-wise, they're pretty identical - the 845K has a built in subwoofer, making it Onkyo 2.1 sound over the 805's 2.0, but I'll be running it through my amp & Mordaunt Short 7.1 system, so it's not a deal-breaker.
Price: there's £50 between them, so no meaningful difference...
Heart says go for the newer 805K, but head says wait for reviews (and any Black Friday deals).
Budget is a grand, so if you've got any better suggestions for a 65", 144hz TV either mini-LED or OLED, let me know.
Help me choose:
QD-Mini LED 4K TV 65 inch - C805K
TCL C80K Series QD-Mini LED 4K 144hz TV with QLED, Google TV and Game Master Pro 2.0 , learn more.
www.tcl.com
Or
4K Mini-LED TV 65 inch - QLED TV - C845K - TCL UK
TCL 4K Mini-LED 144hz TV with QLED, Google TV and 2.1 Onkyo sound system
www.tcl.com
