Play around with the codes, deselect the football 20% off and apply the refer a friend first.Looked into this and I just can't see the prices you are quoting. LG direct are doing 20% off. So that's the 83" C4 for £4,799.98. The 83" G4 is £5,99.98.
I did the whole 'refer-a-friend thing', got the code for an extra 10% but it doesn't let you use it if you are already using the 20% code.
So not sure what I'm doing wrong here.
Also make sure it's a new account for the 5% sign up bonus.
, but now the 83" G4 is out of stock
) in the last few days my tv has started to restart itself, I’ve changed from Sky puck to our Fire stick and it keeps doing the same, should I factory reset it? I got it from Richer Sounds with the 5 year cover got it back in 2022 I think ….
