Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
Yea, it's all in the link you've posted - https://www.nintendo.com/en-gb/Supp...l-Games-Across-Multiple-Consoles-1647413.html
On only 2 consoles, the primary console can play games with no restrictions, but the secondary console can only play games borrowed as if they were physical games card; one-by-one. And you need to go through that online check every time you load that eShop game on the secondary console. And that's how my two Switches behave. The first-time only must have the two consoles close to each other is a one-time DRM check-up. Then every time you load the game on the secondary console the DRM will check if the primary console is online.
Physical games won't have this restriction. Or the Switch 2 needs to be the primary console.
I'm going to have the same rubbish when I open-up my system on Sunday.
Just rereading your post....
Having the Switch online shouldn't be a problem, but having it paired every time for every game would be. Imagine if I buy a new eShop game....because switch 1 is the Primary, I won't be able to play it on my Switch 2.
If I make Switch 2 my Primary, that sounds like it will lock my Switch 1 out of the eShop games unless ir pairs.....and any new games I buy won't do the current arrangement where it auto download and install and let my nieces play them.
Unless of course I just get all physical games only, which I want to do but you know how some games won't be, especially if they are going to be larger than 64gig.
