Here we go G6 Pro: https://uk.store.ui.com/uk/en/category/cameras-bullet/products/uvc-g6-pro-bullet?c=GBWow, they finally released a 1/1.2" sensor 4k camera. Had my Hikvision versions of these for about 3 years now.
I'd be curious to see the price, I imagine they'll still be at least 3x the cost though.
Why not just buy direct from Ubiquiti?Looking at buying a USW PRO HD from another retailer that offer 3 years free cloud hosting. I dont need the hosting since going for a cloud gateway but the NON free cloud hosting is out of stock and back order but the version with the hosting is available. Anyone bought this and just reset it when delivered?
Delivery timescale. I've ordered direct on Tuesday and its still not here. I'm expecting it tomorrow as I've had a note from the Carrier... Could do with it for Saturday. If I'm stripping the network the weekend is better less work disruptionWhy not just buy direct from Ubiquiti?
Id love those speeds, just because. But it's definitely unjustifiable, I'll push for 900 in March when I swap from Aquiss 300 to probably Plusnet 900 them being similar price.
I don’tThose ucg fibres are a little gem. Do you cry a little bit on the inside though having only 100 up?
All I can get sadly. Still miles better than my old house which still can’t get FTTP.Those ucg fibres are a little gem. Do you cry a little bit on the inside though having only 100 up?
Just have different accounts in Plex and lock yours down. You can easily choose what media is available to each account.Hi Folks,
My UNAS PRO has just been delivered 7 14tb Shucked drives installed 5x WD 5400rpm + 2 EXOS 7200rpm
This is going to be used for Media Storage, Plex and Photo storage.
I could do with separating the Ahem "Adult" media from the Hollywood film and TV so only certain accounts can access certain media via Plex.
Would multiple storage pools be the best way. Only really need minimal redundancy at this point.
Also thinking about the future and different sized drives, Whats going to be the best setup with this to then increase drive size in the future. For instance if a 14tb drive fails I might as well replace with a 20+tb drive only using the 14tb currently as I have some spare
Thanks
