OK. So with the new machine up and firing on all cylinders I set about finishing all of the machining. And I won.
First up were 8 15mm magnet spacers from an old piece of white 5mm.
I did not realise you can set tabs to be singular and tiny. So I did.
Those are all filed and done. Next up carbon.
If you look closely you will see the dot in the first i went flying. Sadly so did the second one. As such I just machined four with small tabs. I then moved onto the main event. This took 1hr 20 mins. On the old machine it would have been about 4 hours.
Like, it's so good you can barely even make out the machining marks.
I need to carefully clean the carbon parts now, and file off the tabs from two of the i dots.
Now, can it handle 43cm long acrylic slabs?!
