- 18 Oct 2025
- East Ayrshire
I can’t do that today. Too much use going on. I’d be beaten to death by my family.Would it be possible for you to try one thing? Disable the WiFi on your Router. And then tell us if your wired network still works? Because I suspect that it won't work without the WiFi on the Router, or the Extenders powered on.
Disabling Wi-Fi on the main router though doesn’t just disable WiFi, it can also break the management/control path between the EE hub and the satellites, even if they’re wired for data. The test wouldn’t prove anything about the physical topology — it would just intentionally break the mesh system.
The facts remain:
• All downstream devices pull DHCP from the router.
• They receive 192.168.x.x private IPs.
• NAT and firewall clearly occur at the router.
• Traffic flows at >1Gbps through the switch before hitting the router — proving the switch is not acting as a router or broadcast boundary.
So logically, the switch is still L2 fabric, and the router is still the L3 boundary. The physical order doesn’t change that.”
