Yeah it's actually not that bad once you set it up!I've switched off loads of crap as recommended on here, looks a bit better now.
On positive side have to say upscaling is superb compared to my old C9, which wasn't bad either.
The soundbar is pretty good as a secondary sound system but glad I didn't get rid of by BK Mono sub and wharfedales for it
Yeah they have their place but play a decent CD and soundbar lack in hifi stereo. For TV shows good enough but action movies you'll notice the differenceI've used a couple of very similar ones - what do you mean, top part?Anyone used this stand:
Sanus VTVS1-B2
Installed, but the tv rests on the top part…should it rest on top and bottom?
Expert drawing:I've used a couple of very similar ones - what do you mean, top part?
Pics will help.
Gotcha. This looks ok to me - just need to fully thread in those 2 long screws as they stop the bottom of the bracket being lifted away. Doesn't need to be done up tight, just enough that you can't remove the TV by tilting the bottom forward.Expert drawing:
imgur.com
Discover the magic of the internet at Imgur, a community powered entertainment destination. Lift your spirits with funny jokes, trending memes, entertaining gifs, inspiring stories, viral videos, and so much more from users.imgur.com
The vertical bars are installed with two screws on each bar
I’ve screwed them up, so assume the are up against the metal of the bracket (there are no holes) which I assume keeps it stableGotcha. This looks ok to me - just need to fully thread in those 2 long screws as they stop the bottom of the bracket being lifted away. Doesn't need to be done up tight, just enough that you can't remove the TV by tilting the bottom forward.
Honestly, these days I'm suspicious of black Friday deals. Certainly don't assume it's the best price you'll see all year.Does anyone know what would be a good price for the LG G5 65” on Black Friday?
