Do you ever get close to using that on the roads though?
It'll probably be a combination of it being the top trim so probably not as popular as slightly lower trims with extra packs added or them just not being listed properly on AT.Hello, was the ID3 Pro Max a big seller? I like the combination of electric seats and DCC as standard, but Autotrader reports only 12 being available from £10,000 to £20,000
. My last two cars where BMWs and I hoped they'd get past this "I ****** my cousin" stage but alas not.Shame you had a bad experience with the i4 because it ticks all those boxes. I spec'd it with the towbar and fitted a bike rack with heavy ebike. Used it for the first time yesterday and absolutely no issues.My budget is £40,000 and criteria is a car big enough for a medium size dog and all that comes with that. Needs to take a towbar to carry my heavy ebike, rapid acceleration, fun, well built with nice interior and decent range 200 miles plus. So far dealers are non committal on a cars that can take an aftermarket tow bar.
Agreed, looks totally daft. Even more so with the rubber band profile tyres and massive arch gap.BMWs are an example of too much inbreeding if cars could eh, breed. My last two cars where BMWs and I hoped they'd get past this "I ****** my cousin" stage but alas not.
While I'm having a moan about car design, what's with the latest trend of wheel arches that don't follow the profile of the wheel? Not a good look imo.
I look forward to trying a sub 5 second 0-60 EV. I'm sure it's a buzz but I just can't see me ever tapping into that performance (or anywhere near) on the roads.Yes, regularly.
Or to put it any other way, it’s an all include lease and I’m not paying for the new tyres it will need before it goes back, it’s almost inviting it!
If I was paying for the tyres, probably not as regularly.
Mine is a max and I definitely think it was worth paying the little extra to get all the kit.
I think the tour also comes with a lot of the same extras you get in the max minus one or two but obviously has the bigger battery as well.
Maybe that is just indicative of the type of driving I do and the roads I'm on.
Would you recommend it? Is 200PS "enough" in a 1800kg car? I've got an old Golf with 210PS but without the 300Kg of lithium.
I was looking for a MK7/MK8 with DCC and then spotted the Pro Max's have pretty steep depreciation, so I can get a 2021 low mileage one for £16,000
Does that answer the question?My ID3 only has 200ish bhp but to be honest with the pace of its acceleration I don't feel like you need any more for general driving. Still feels more rapid somehow than bikes I've had that'll do 0-60 in half the time.
That's not too say I won't be swayed when I get my next car because bigger is always better![]()
I think the difference in the way EVs deliver power makes them feel much more rapid than an ICE with similar stats.Rear drive cars are fine and the traction control systems are very good. Fwd EV are terrible in winter thoughIt's not so much the power but the instant torque from EV's, that's where the performance comes from. The problem is that with the state of our roads and the fact that they can often be very greasy it can be difficult to put that power down.
Yeah, I will try another dealer although that’s 2 out of the three local ones that have been a poor experience. In the past 15 years I must have bought three BMW’S from one of them and two the other!Shame you had a bad experience with the i4 because it ticks all those boxes. I spec'd it with the towbar and fitted a bike rack with heavy ebike. Used it for the first time yesterday and absolutely no issues.
surely that depends on the EV?.Power comparisons between EV and ICE aren't really meaningful. The EV will respond instantly even at low speed, but it won't deliver higher end power in the same way. On normal roads, especially in urban areas,the EV is just way better feeling but if you ever want to take it on track? Well, I haven't tried it but my experience on unrestricted autobahns tells me the EV runs out of steam at about 80-90mph.
Unless you're drag racing it's really not noticeable.80-90 is fine, reading about the ID3 they say its strong to 50 and then tails off. I was hoping for 60
