My son's rig (5700x3d, 2080Ti) is in a loop roughly the same age. I change the fluid and blow the dust & cat fur out of the rads annually, but it's otherwise been problem free.I've had a custom loop for 8 years now and it has served me really well also in the sense that I don't change parts as often anymore because it's so 'difficult'.
I just rebuild my loop to the another case. All the fittings and ZMT tubes looked pristine and I only swapped few tubes and one fitting. Never had any leakage while running my loop with soft tubes and EK premixed liquid *knockknock*.My son's rig (5700x3d, 2080Ti) is in a loop roughly the same age. I change the fluid and blow the dust & cat fur out of the rads annually, but it's otherwise been problem free.
Likely replace the GPU in the new year (9070XT) and he's asked for a SFF case, so I'm looking forward to putting the MoRa 420 to work.
That's another thing that stopped me going with an AIO. With a custom cooled system, you can swap out parts that fail easily, or build in redundancy for pumps, etc. Good luck with the full system - what is your WC setup?I've actually just gone back to a full WC'd set-up, I was on air, decided I wanted an AIO, bought the very nice EK-Nucleus AIO CR360 and within 2hrs of use it had a nasty vibration noise coming from the CPU block, turns out this was a common complaint with this model.
So, with all this, I didn't really see another AIO that I wanted, so I thought I'd just build a basic loop for the CPU only, and then I made the mistake of looking at water cooled GPU's
So I've now replaced every part of my original build (apart from 2 NVMe drives) and gone full water, just waiting for the last bits tomorrow to start building it all, can't wait, I love looking at the low temps and having a quiet system, plus it looks the bees![]()
Yeah, the AIO failing so quickly just made me realise that as well, so like you I just thought I'd much rather a full WC set-up and do it properlyThat's another thing that stopped me going with an AIO. With a custom cooled system, you can swap out parts that fail easily, or build in redundancy for pumps, etc. Good luck with the full system - what is your WC setup?
Nice set-up that'll be! Personally, I'd go with the EPDM/ZMT tubing - it's far more durable than the PVC tubing. Good luck with the build!Yeah, the AIO failing so quickly just made me realise that as well, so like you I just thought I'd much rather a full WC set-up and do it properly
WC set-up:
* Iceman CT3 CPU Block
* 1 x 360mm EK-Quantum Surface P360M X-FLOW Rad
* 2 x 240mm EK-Quantum Surface P360M X-FLOW Rads
* Alphacool Eisblock GPU block
* Alphacool D5 Pump + Plexi Top
* EK-WB EK-RES X4 250 (R2.0) 850ML Glass Reservoir
* Barrow Brass Fittings
* XSPC Pure Clear Premix
* XSPC Clear Tubing (though I am considering getting some ZMT tubing instead?)
That's the main bulk of it, what are you using at the moment?
