Awesome. Thank you so muchcmd-t, cmd-l
It’s two key strokes but it quickly becomes muscle memory.
.Awesome. Thank you so muchcmd-t, cmd-l
.Thank you. I exported my bookmarks and then deleted them all from Safari and then re-imported them again and it seems to have worked.Ahh, now this is one, where, on my MBA, I find I need to edit one for them to sync. I have a bookmark which I keep just for this purpose. Try editing a bookmark, see if it kicks the sync off.
.I haven't noticed any problems. Seems like a good time.Might update from Sequoia now .1 is out on my m1 pro MacBook.
Well I’ve noticed that if I double click in the vicinity of where the menu bar is located before it’s actually loaded it seems to lshow up pretty quickly. Of course if I’m wrong about this I’ll report back but if you don’t hear from me then all is good.I've uploaded a video onto YouTube showing what I mean. Sometimes the menu bar doesn't load for several seconds, other times it loads pretty much instantly...
Good to know... was debating upgrading my wife's machine (same spec) but may hold off...I shouldn't have upgraded. Admittedly I am on an 8GB RAM M1 Air but application launcher is hideous, it stutters as it loads and then icons follow shortly after.
It is marginally better after a reboot but it's completely killed off my love for it. I tend to use my work laptop now.Good to know... was debating upgrading my wife's machine (same spec) but may hold off...
Same with my base M1 MBA.I’ve got a base spec M1 Mac mini and it’s working perfectly well under Tahoe, not stuttering or anything as mentioned above.
Do you happen to use a lot of Electron based apps? There's been a bit of an horrendous issue due to Electron using a Private API that they shouldn't have been and it causing severe lag & stuttering...it's apparently been fixed in 26.2I shouldn't have upgraded. Admittedly I am on an 8GB RAM M1 Air but application launcher is hideous, it stutters as it loads and then icons follow shortly after.
9to5mac.com
Finder? That’s the worst at the moment.Do you happen to use a lot of Electron based apps? There's been a bit of an horrendous issue due to Electron using a Private API that they shouldn't have been and it causing severe lag & stuttering...it's apparently been fixed in 26.2
Latest macOS Tahoe beta fixes bug with Electron apps that caused widespread performance issues - 9to5Mac
After macOS Tahoe launched, some intrepid developers noticed that Electron apps could cause the Mac’s rendering system to be overloaded...9to5mac.com
