- 3 Jun 2005
- The South
Hi all,
Looking to get our 70s fused consumer unit replaced and i'm now wondering what i should be on the lookout for when getting electricians in for quotes.
Am i right in thinking all CU's now need to be metal/steel/non-combustible rather than plastic (18th edition etc)?
What certification or paperwork should i receive upon completion of the CU change?
From reading around i should receive at least an EIC (Electrical Installation Certificate) although i have seen others mention an EICR (Electrical Installation Condition Report) should be done before/afterwards and if that happens, there will be a EICR cert. as well.
Does the local authority/council (in England) need to be notified and if so, who does that?
If they are registered (i'm guessing that means they're a Part P member and/or part of a scheme?), what is the process?
I've seen some mixed answers on this whilst doing a Google but some mention that upon completion, they (electrician) should(?) notify their scheme/membership of the work who will issue the EIC cert. and notify the local authority - is that the case?
If they're not registered and the electrician does provide an EIC, what happens thereafter especially if selling the house?
Am i right in thinking it's then up to me to get it properly "signed-off", which will likely involve getting a third-party in to actual certify it all?
Is there anything else i should ask or check to make sure they aren't a complete cowboy?
Appreciate it
Appreciate it
