CCTV advice
7 Sep 2008
Hi all,
There have been a few robberies nearby, which has left me and my family feeling concerned.
We already have one wired Google Ring-style camera with floodlights, and it’s been working well for years.
I need to add two more cameras, but I’m a bit out of touch with the latest technology.
I’m considering buying two more Google cameras because they would all work in the same app and be easier to manage.
However, when I look at CCTV systems with four cameras, they often work out cheaper.
What I’m trying to work out is:
- Which two additional Google cameras would I need if I want them to be hard-wired rather than battery-powered?
- If I went down the CCTV route, I already have Cat5e cables running exactly where I want the cameras, and I’m using a wired network.
- How could I use the existing wiring to combine both a wired network and a CCTV system?
- I’m hoping to avoid drilling more holes into the house for extra RJ45 cables, so is there some kind of external splitter or similar device that would let me do this?
Thanks for reading.
Loads of advice on here https://forums.overclockers.co.uk/threads/spec-me-a-cctv-system.18568132/page-236
I had Amazon Blink Cameras. Due to location and high footfall i was burning though batteries at a fast pace. As in rented accomodiation i was unable to use PEO hardwired cameras. I go the following https://www.amazon.co.uk/dp/B0D1KK1FGC?ref_=ppx_hzod_title_dt_b_fed_asin_title_0_0 on offer for only £230. Its night and day difference over the basic battery camera and Reolink are well recommended here on OCUK forums
As you already have CAT5e cabling in place , that supports POE so 100% you should be looking at POE wired camera system example would be the following
There are loads of options on camera quality 5/8/12MP , fixed position, tracking etc so really down to what you want to spend.
thanks i will take a look
from what I have learned so far its likely im going to need to run some extra cat5e cables ie 3 cameras and 3 cables because from what I can tell so far is on some of these external poe switches ie 2 into 1 for example u would lose the speed from 1 gigg to 10/100 for example
im just trying to understand if I ran the three ethernet cables if I can plug those other ends away from the camera into a POE switch so that the cameras will work ie is there ne need to plug the cameras directly into the NVR unit or can the NVR unit be connected to the network and would the cameras work ahh I might just have to buy everything test it out cables etc and then drill holes
so long story short it looks like I would need to run an extra 3 rj 45 cables into a POE Switch.
If you can get power to loft assuming all cameras are high level roof wall mounted. then 4 Camera > Loft POE Switch > 1 Cable to NVR reduces your cable runs from 3 to 1
*** No competitor Links ***
Thanks might draw the diagram out to explain the current setup
I think not all switches are poe
I may need to buy a poe switch but there is no need to connect the camera directly to the nvr?
The nvr just needs to be connected to a poe switch or my router? Is that right?
The loft dont have easy power and the cameras will not be high up
NVR and Cameras just have to be on the same network. Some NVR have PoE ports for direct connection of cameras, but you don't normally have to use them, you can connect a PoE Switch or PoE injector nearer to the camera.
With something like the Ubiquiti USW-Flex switch, you can run 1 cable to the outside, power it via a PoE++ injector, and then run between 3 and 4 cameras off it depending on draw - all whilst running at 1Gbps.
There's even a USW-Flex Utility cabinet to make it all look nice.
So you'd end up with something like this
I you don't currently have a separate switch, then disregard that, the NVR and POE++ injector would connect direct to your Router.
Similarly if you do have PoE++ capable switch or want to buy one then you wouldn't need the PoE injector.
Thanks that is a rather expensive solution the uniflex switch
It's that vs drilling one extra hole and feeding 3 new cables through to a POE switch.
which system/made would u reccomend that's easy to use on par with the way google have the ring software setup
But is good quality proven equipment that meets your original requirement of not drilling extra holes
Note there are cheaper options, indeed a quick search on your favourite site for "Outdoor PoE Splitter" will probably provide something that will work.
As with all these things, there are several ways of achieving what you want, but some are a time/money trade off (i.e. what you'll save by not buying the above switch, you'll spend on extra cabling - even though it's relatively cheap, time to drill holes, run extra cables etc)
The thing is and what i dont understand is this
Say I got a cable running outside and I split it into two - One end plugs into the camera but can I use the other end and plug it into an outdoor switch but still have my wired network working on the other side of the camera...
let me shiow u an example of the device Ive seen:
Ah the good old "ethernet economisers" :D
They work by exploiting the fact that 100Mbps only needs 4 wires (2 pairs) out the 8 available in a normal ethernet cable.
So itl work but reduce the speed of the network?
Mmm not sure thats good for me because i use the network to send files across to a nas
10/100 would be v slow
If you use those splitters you have to use 2 per cable, one either end. You can’t have single plug on end and split the other.
They will only slow down the cameras connected to them not the entire network but honestly run another cable as it would likely be cheaper than buying those abominations.
QVRPro on my NAS has been rock solid and the software is excellent. Recommend Poe cameras. I use rebranded Duah ip cameras from Amcrest.
What is rebranded duah from armcrest
Sorry, I missed the words “ip cameras” which I have now edited. Duaha are one of the biggest manufacturers of external cameras but they can also be found rebranded at lower prices. Very reliable and solid cameras.
