Cooking a 3 course Italian Meal with AH2
Man of Honour
11 Mar 2004
Had a really good night, had some friends round and cooked Italian, lots of wine and beer. I know there's a lot of people who like recepie ideas and others that simply like to try cooking.
So here's a complete 3 course meal.
Starter : Spinach gnocchi with mushroom and wine sauce
Ingredients
For the gnocchi
600g 5oz floury potatoes (such Russets), unpeeled
600g of Baby spinach
1 large free-range egg
salt and freshly ground black pepper
450g plain flour
For the sauce
300g mushrooms
200g Shitaki mushrooms
1 medium finely chopped
1 garlic clove, finely chopped (or one teaspoon of lazy garlic)
200ml white wine
200ml cream
Finley chopped parsley to serve
Method: Gnocchi *makes about 10-12 starters*
1) Boil the potatoes for about 40 minutes(skins on), until tender. Remove from the heat, drain and leave to cool. Once cooled, skin and mash well in a bowl.
2) Boil a large saucepan of salted water. Wash and pick through the spinach, discarding any withered leaves and removing any large, stringy stems.
3) Blanch the spinach in batches for about 30 seconds, refreshing each batch in ice cold water. Drain and gently squeeze any remaining liquid from the spinach. You need to remove as much water as possible, so make into a thin layer and sandwich between loads of kitchen paper.
4) Finely chop the spinach
5) Mix the spinach into the mashed potato.
6) Add the flour and mix well to form a dough. Knead the dough for 3-4 minutes, until it becomes dry to the touch. This is the hard bit, it really needs to be reasonably dry. As it has spinach in your are unlikely to need a whole egg, so you need to add it as you go, If you don't want to waste eggs, melted butter will also work fine.
7) season with slat and pepper
8) leave in fridge till you ready to use, can be made 24hours in advance if needed, just make sure it's covered so it doesn't dry out.
9) Divide the dough into three pieces. On a clean, well-floured surface, roll out the dough into 1in diameter lengths, then cut into pieces at 1in intervals.
10) Place these gnocchi pieces into boiling water and cook for 2-3 minutes. When they rise to the top they are cooked. Scoop out with a slotted spoon
b]Method:[/b] Sauce
1) Add a tablespoon of olive oil to a pan on a low heat. Add the Onion and cook for 1-2 minutes. Add the garlic when the onions have turned translucent. Cook until the garlic has taken on a little colour.
2) Add the mushrooms and fry for a few minutes, season with salt and freshly ground black pepper and stir again. Raise the heat and pour in the white wine.
3) When the wine has reduced by two-thirds, reduce the heat, add the cream.
4) toss the cooked gnocchi in the sauce and serve with a sprinkle of parsley on top.
Sorry I haven't got any pictures of this.
Man of Honour
OP
11 Mar 2004
Main : Lasagne with Garlic bread
Ingredients
For the ragu
4 tbsp olive oil
4 celery sticks, finely chopped
2 carrots, finely chopped
1 medium onion, finely chopped
2 cloves garlic, peeled and crushed
2 sprigs rosemary
1000g of lean beef mince
6 rashers smoked bacon. finely diced
1 bottle red wine
2 tins chopped tomatoes chopped
2 beef stock cubes
White suace
Pint and a half of Milk
60g plain flour
60g butter
2 bay leafs
salt + butter
Layering
600g baby spinach leaves
Lasagne pasta
Grated cheddar or mozzarella
Grated parmasen
Method: Ragu
1. Heat the olive oil in a frying pan and fry the celery, carrots and onion for approximately 15 minutes. Add the garlic and rosemary.
2. Add the diced bacon and fry for a few minutes then add the beef mince and cook until the liquid from the meat has been absorbed.
3. Pour in approximately 2/3rds of a bottle of red wine and stir well. Cook for approximately 45 minutes (until wine has almost completely gone).
4. Once the wine has evaporated, add the tomatoes, stock cubes and the rest of the wine. Ccook slowly Until it has reduced to a good sauce consistency (think of the same consistency as spag bol)
5. To make the White sauce, place the milk in a large non-stick saucepan, add the flour and butter. Turn heat on to medium and stir continuously untill it starts simmering/
6. Once simmering, turn the heat down (very low) and add the bay leafs, salt and pepper and leave to gently simmer for a further 2 mins, stirring occasionally.
7. Remember to remove the bay leafs before assembling the lasgne.
Assembly
1) Get a large oven proof dish and use half the ragu to cover the bottom of the dish
2) use half the baby spinach on top of the ragu.
3) put one layer of lasagne on top of the spinach
4) place half the white sauce on top of the pasta
5) repeat 1-4 with the rest of the ingrediants.
6) finely Sprinkle the parmasen and cheddar on top, or slices of mozzarella if you prefer that.
&) bake for 20-40mins at 190, untill top is golden brown - dark brown (depending how you like it), this one was for 40mins and is nice and crispy.
Garlic Bread
Ingredients
1 French stick cut in half
6 table spoons of butter
6-8 cloves of garlic mashed up with salt, or 6-8 teaspoons of lazy garlic
Method
1)Get the two halves of garlic breads and slice almost the entire through the bread, at about 1cm spaces.
2) mix the butter and garlic together, if your using lazy garlic add a little salt.
*if your using cloves, finely chop, then add a good couple of pinches or sea slat, with the edge of the knife, grind the slat and garlic together until you get a paste.
3) rap in tinfoil
4) cook at 190 for 40mins
Man of Honour
OP
11 Mar 2004
Dessert: tiramisu
Ingredients:
2 sachets of instant custard
1 tub of mascopone cheese
300ml cream
1/2 a pint of boiling water
6 teaspoons instant coffee
3 teaspoons of sugar
6 squares of good dark chocolate
Optional
Tia maria or any other coffer liqueur
1 and a half boxes of sponge fingers
1 tablespoon sugar
1 cap vanilla
Method
1) a sachet of instant custard usually requires 3/4 of a pint of boiling water, however we need it to be thick. So for two sachets of custard use 1 and 1/8th pints of water. Mix well and place in fridge to cool.
2) make up the coffee, with the sugar in it. It should be very strong, don't add too much sugar, it should still be slightly bitter. Place in fridge to cool.
3) once they are cool, get the custard out and mix the mascapone in, until you get an even colour.
4) get a suitable container and pour the coffee into it, something which is easy to dip the sponge fingers into, if your adding liqueur pour that in as well.
5) get a suitable dish for making the dessert in.
6) Get several sponge fingers and place in the coffee and leave for a few seconds to absorb, the idea is to get it totally soaked all the way through, without falling to bits. If you've never done before, experiment and eat the failed ones. Put one layer of soaked fingers on the bottom of the dish. If tehy look a little dry you can always get a spoon and pour some more over the fingers.
7) layer half the custard mix over the fingers.
8) repeat steps 6 and 7 with the rest of the ingredients, don't worry if there's any coffee left, just throw it away, you don't want the thing dripping.
9) get the cream sugar and vanilla and whisk till soft peaks, spoon over the top and smooth over
10) get the dark chocolate and grate over the top, place in fridge until you are ready to serve, will easily keep several days.
