Basically there are only a few companies that manufacture their own PSU's seasonic being the main one that springs to mind.
Other companies simply rebrand PSU's under their own name... Corsair uses Seasonic (or used to) etc...
Brands with established reputations tend to charge more for their products, the advantage is their longevity and reliability, you will invariably get your money back 3 years down the line with a high quality psu still running fine.
In my opinion because of this i always say dont skimp on your PSU, it will still be running in 3 years if its good. As this is the case dont say, 500 watts or whatever is to much power for my immediate needs...
Think about what you might need in a few years and it will save you forking out the same again for a new PSU.
Good brands are: Corsair, Seasonic, OCZ, Tagan, Antec, Coolermaster, Zalman...
If you agree with the above then spend 100 on a PSU:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-013-CS&groupid=701&catid=123&subcat=
Or a 700w for 67GBP:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-032-OC&groupid=701&catid=123&subcat=
If not then this is a great 500w PSU:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-034-CS&groupid=701&catid=123&subcat=
this is my 50 cents having had good and bad PSU's
