106 door trim
28 Dec 2004
Derry
I've probably called it the wrong thing but on the drivers side door (outside) there's a strip of plastic running horizontally across it, it's fallen off my wifes car (the clips that hold it on were damaged), does anyone know where I could either get hold of the clips or a new bit of trim? (preferably not a scrapyard as they're few and far between). Thanks.
there's a few online breakers yards, they should be able to help you out. failing that, Peugeot do sell them, but I think you have to buy a full set. Have you got a picture of the clip(s)? I might have a few lying about.
I'll dig what's left out tomorrow, cheers.
If you still have the trim, the clips will cost a couple of quid from Peugeot mate, go to your local dealer and find the parts counter...
