Hi everyone, I'm about to embark on my first PC build in quite a while and have decided to go the way of a dual loop water cooling system. This will be my first w/c build so i'm likely to buy some components with blocks pre-installed to make it a little easier for me. I am hoping i could call upon the experience of you guys to review my planned set-up and any advice and suggestions will be very much appreciated.
I'm looking to install this dual radiator set-up in a Thermaltake Mozart case as i believe this may be the case that provides the most room due to it's monsterous size! Any thought's on other case options for internal dual rad set-ups would again be very welcome.
Loop 1
This loop will cool the CPU (Intel QX9850 or QX9650) and chipset which will be on an EVGA nForce 680i SLi Black Pearl motherboard
Main Cooling Components
Thermochill PA120.3 Radiator
3 x Noctua NF-S12 Silent 120mm Case Fans
EK Multioption Reservoir 150
Laing DDC 12V ULTRA Pump & Plexitop
Loop 2
This loop will cool the SLI graphics cards which are likely to be either 2 Black Pearl 8800GTX's or Ultra's
I may also opt to watercool the ram and am considerring doing this via loop 2.
I'm hoping to end up with a powerful, cool and quiet PC used mainly for gaming.
Loop 1
Loop 2
