2-pin phone plug query
27 Jul 2015
Just a quick question really. I bought a Xiaomi Mi9 the other day, and the plug on it is 2-pin. Do I need a special adapter for this in UK socket, or just any old 2-pin shaver adapter plug? I don't want it to explode!
Thought it was illegal to sell items in this country that didn't have a standard 3-pin UK plug.
he doesn't say he bought it from the uk....
@op - just any charger will do that fits. (USB-c) - if you want to use the one supplied then yes - any standard shaver 2 pin adapter will do
If the charger states it can receive 230v AC, then any adapter will work. However, the phone is still USB so you can use any charger for the phone. The Mi 9 supports Quick Charge 4+ so for fast charging, it's compatible with both Quick Charge and USB-PD chargers.
