I love how you constantly post the single post in isolation
Without quoting my reply.
http://forums.overclockers.co.uk/showpost.php?p=17988341&postcount=245
I've challenged you on numerous ocassions to proove me wrong but instead you ignore it.
The reason why I didnt quote your reply and why I've not 'proven you wrong' is because you still don't 'get it'. Your reply is completely irrelevent to the point I was making. There is no requirement to 'proove you wrong' because you were not wrong in what you said. Why would you be wrong in what you said - it wasn't actually your text.
I'm not sure we want this thread to degenerate into another insult-fest but I guess it would be helpful if I spelt out exactly why people find the post so amusing.
It has nothing to do with you using sources and Wikipedia to jog your memory. Everyone does that - we all do it all the time.
It has everything to do with the fact you willfully and deliberately plaigerised somebody elses work and attempted to pass it off as your own to maintain the impression that you have a certain level of knowledge on these forums. I've no idea why you feel the need to do this, nobody else does, and why does it even matter, but the fact remains that is exactly what you did.
You took that Wikipedia article, pasted it into a new reply window or a word document or something, and then set about subtly changing the odd bit of it so that it wouldnt appear quite so obvious that you had lifted it straight from Wikipedia and attempted to pass it off as your own knowledge. It is so obvious this is what happened - as I said in the original reply we all used to this for homework in Year 7 using Encarta
You were not even very good at doing that, which is why it was so obvious - you forgot half of some of the sentances.
ie 'The election resulted in a Conservative landslide victory, with the now leaderless Labour Party winning only 46 seats' was edited by you to read 'a landside win to the conservatives with the now leaderless labour party only winning 46 seats'
ie you simply changed the first bit a tad. The entire second part is directly copy/pasted.
Hopefully this explains it to you. It's nothing to do with whether the information was right or wrong, it was obviously right. It's everything to do with the deliberate attempt to pass it off as your own knowledge - this is not simply a case of forgetting to reference sources.
When you combine this with how prolific your posts are on such a wide range of topics, everything suddenly fits and people find that hugely amusing.
There is no hidden agenda. You are not the new MikeHiow. Nobody hates you. We just found it hilarious.
Can you imagine the backlash on this forum if somebody found ME doing that? Exactly - it's a hot topic because you post loads, not because of anything else
