- 18 Apr 2019
Hello,
I purchased a 2080 Ti Ventus.
First of all, I received a non-OC model even though I ordered an OC model. The only difference is a small sticker on one side of the box, MSI should differentiate the packaging more than that. Be careful if you order this model.
I have a fan issue with it. When I first installed the card, it was very quiet.
I let it run some calculations overnight and now one of the fans is making a friction (?) noise. It is not rattling. It is a "shhhhh" noise, as if a part of the fan was constantly rubbing against another part. It sounds like a lack of lubrication.
It does it at any speed, even when I manually spin the fan.
I tried removing the fan and putting some oil on the sides and in it (by removing the sticker on the back), but it didn't change anything.
It is the 3rd card I order and I am very tired of RMA processes, I need this card for work. First one (Gigabyte Gaming) had a "dishwasher" sound problem, second one (Gainward GS) never arrived ("lost" in transit).
Is there any way to fix this so that I don't have to send it back?
Thanks
Thanks
