2900 XT Waterblock, will it fit another card?
Probably not. These full cover blocks are only designed to fit a single card which is why i will never buy one. Core only blocks are a much better option as you can keep using the same block. Mine has been on 7800Gt/8800GT/4850/4870 cards. Better cooling too.
Extremely well mine is the Pro LE version. The MP-1 on the gpu is still excellent too. The highest i have seen on my E8500 is 42 degrees when running IBT. My 4870 run's in the low-mid 30's at load. :D
I do have a window mounted Nexxos Extreme lll rad though.
