2nd monitor for PS3 and dual screen?
8 Oct 2006
Clifton, Bristol
Just need some suggestions really.
At the moment I have a Dell 2407 screen that is connected to my PC.
Anyway, I just got a PS3 quite cheaply and was wondering what monitor to get which will be the same resolution as the Dell (so I can use it as a 2nd screen with the PC) but also good for PS3 gaming?
The 2407 doesn't have HDMI so I can't connect it up with the HDMI cable I got with my PS3 ........ :p :(
Or am I missing something obvious? :confused:
I got my PS3 connected to my 2407 via a HDMI-DVI adaptor that came with my mobo.
Oh cool!
I have something similar to that, how do you output the sound though? :o
Bit more complicated, use the AV cables (red,white,yellow) and connect a phono adaptor and a 3.5mm coupler to the red and white(sound). You have to enable the sound to go through the separate lines in a setting in the control panel. can't mention the shop cos of competitor rule but you can find them on the high street
a second monitor doesn't need to be the same res.. throw a 32-42" 1080p HDTV in for the PS3 and use the connection like above for DVI-HDMI so that you can use your tv as your second monitor.
I've done it for a few years now and its awesome so long as you buy a decent 1080
I doubt a 32" - 42" TV will fit on my desk at UNI :p thanks for the suggestion though.
Only reason why I was thinking it needs to be the same res is because I thought both monitors need to be the same res to be able to extend the desktop from the 1st screen?
If Dell still made the 2408, I would have bought that without thinking twice :o
Second monitor doesn't need to be the same res. I 've had different res monitors for years. It certainly makes it easier if you have two of the same ones.
