So I have wondered this the last week or so and opened up a thread asking if anyone had done this. Turns out no-one really had but 'PieEater' shared my wondering thoughts and I put it on my 'To Do' list and I ahve been doing it tonight.
Okay so the question being; does 2x 80mm CPU fans pull their pants down over 1x 80mm CPU fan?
My specs are as follows;
AMD64 3500+ running at 2.2GHz Stock.
2 GB RAM (4x 512mb).
6800GT 256mb clocked toooo….oh I don’t know. (Stock cooling)
550W PSU.
So Cooling wise in my computer I have;
1x 120mm rear exhaust fan.
1x 120mm PSU fan (looks 120mm to me).
1x 80mm CPU fan (stock AMD fan and heat sink).
1x PCI exhaust fan (seems to me a bit of a pointless buy but hey).
So basically I was wondering on cheap ways to cool down my computer. And I came across the idea of putting a spare 80mm fan on top of the CPU 80mm fan I already have running…..But I lost my spare 80mm fan so I’m taking one from the family computer for this purpose.
So loading up Everest I can tell you currently my CPU is running at 30 Degrees under no load and spinning at a 3184 RPM. I have MS Word, MSN, Everest and Firefox running so as I said no load.
So now if I plug in the spare 80mm fan to my CHA2_FAN socket it spins nicely as wanted. Now I have taped the other fan onto of the current one at its started spinning.
So now before mod: 30 Degrees – 3184 RPM
Initial (1/ 2 minutes): 32 Degrees – 2909 RPM
5 minutes: 34 Degrees – 3375 RPM
10 minutes: 34 Degrees – 3668 RPM
Conclusion: No gain, just the most annoying noise of the air cutting between the two fans. Temps went up ~4 Degrees and fan ~484 RPM.
So that was the fan the default way round…hmm I wonder what happens when I swap it around the other way!?
So put the other fan back on and the original fans spin rate.
So now before mod: 30 Degrees – 3182 RPM
Initial (1/ 2 minutes): 30 Degrees – 3516
5 minutes: 29 Degrees – 3516RPM
10 minutes: 29 Degrees – 3514RPM
Conclusion: There is not much more noise produced than the original single fan, but a louder noise none the less. I guess it could be explained like the noise 2 fans spinning instead of one
So after about 10 minutes it’s still hovering around 29/30 Degrees and a stable 3516 RPM from the fan so nothing really to report here.
550W PSU.
