3 hours well spent
24 Apr 2004
Warrington, UK
Yesterday I spent a good three hours washing, polishing and waxing the paseo and here are the results.
thedazman
That colour looks like it polishes up well.
Out of intrest does it show the dirt much when its not been washed for a while? Looks like a good one.
You need some of that black sticky stuff for your tyre walls though :D
Megiuars 3 Step Deep Crystal set
1. Paint Cleaner
2. Polish
3. Wax
I wash the car originally with Megs NXT Car Wash with a lambswool wash mitt, used the megs water magnet drying towel to dry the car then applied each of the above in numerical order using megs applicator pads, wipe off with a microfibre cloth, im pleased with the way its turned out :D
edit as for the wheels thats the best i could get them i havent got any cleaning stuff for them, they are going to get professionally refurbished soon as they are quite battered.
thedazman
Cleaned my car the other day... its now splattered with an assault from what must be multiple birds.. which is odd because its not even parked under the wire they sit on.. :(
I have that problem to behind my house major construction work is taking place the dust that comes from there sticks to my car like a magnet, as for my car showing the dirt you cant really tell only when its sunny then it shows.
thedazman
Alloys were the best i could get them, they have something on them that doesnt want to shift, i am going to get them professionally refurbed soon tho.
thedazman
