3 more sand sculptures
20 Apr 2003
in a house
these were all taken on sun around lunchtime, sun kept popping in and out so was always juggling exposure.
C & C always welcome :eek:
350D, 18-55 @ 27mm, 1/200th @ F11 iso100
as above @ 21mm, 1/250th @ F11
as above @ 27mm, 1/200th @ F11
Not bad
2nd one has good composition, as a suggestion you should have maybe got the hand at the bottom in the frame.
first is ok,
not a fan of the last.
Also use flash outside in harsh sunlight, it reduces the nasty shadows on the first and last
thxs for the input ChroniC, still fairly new to photography so easy to forget little things like making sure all that you are trying to shoot is in the frame. I was mostly trying to avoid getting some of yarmouth's ugly seafront buildings into the background as well as juggling exposure. i admit the last is a bit "holiday snap", it was 1 of the few i recognised and liked but couldn't avoid the clutter in the background
