- 10 Jun 2010
- Scotland
After spending the last week speccing a system and deciding between AMD & Intel. I have finally decided on this system.
I was initally going to go for the Coolermaster 430 with the bundled 500W PSU. However it is out of stock and after reading some poor reviews on the PSU, I decided to opt for one a little more expensive and hopefully it will pay off.
I realise the case and the psu are out of stock, however can't really afford to wait till they arrive in stock and will probably order them elsewhere, however the rest of the main components will be bought from OCUK.
Just wanted everyones opinions on this system. It won't be used for heavy gaming, so onboard GPU is fine.
I realise a lot of people don't like OCZ Psu's but it's within my budget and seems to get a good write up aswell as picking up some awards along the way from certain magazines etc.
Would you change anything or is there anything majorly wrong with this setup that should be altered?
Cheers
Cheers
