360 and Audigy 2 ZS Platinum Pro
Would it be possible for me to plug an XBOX 360 into the stereo inputs (or any input for that matter) on a creative Audigy 2 ZS Platinum Pro and get the sound in 5.1?
Looking to basically use my PC speakers as surround sound for my XBOX and if this will work it will work out a lot cheaper for me to do it this way than buying a seperate surround sound system for the box. I assume that the computer will have to be left on but that isn't a problem because it is never off anyways.
Cheers for the help.
Matt
Matt
). the ex has more connections too - it has more on the back of the breakout box that you cannot see.
