360/ps3 through monitor, 1440x900?
Permabanned
26 Nov 2006
guildford, surrey
I know These High Def consoles can be run through a monitor (well the 360 can, dont know about the ps3), but can anyone tell me if they would run at 720p through my 19inch widescreen that's native res is 1440x900?
thanks.
The 360 definitely will as that's exactly how I'm running it at the moment (there's a very slight vertical stretch). Pretty sure the PS3 will as well, but I don't have one so can't give a 100% answer.
thanks.
Yes, if you set it to 1080p your monitor may downscale it to 1440x900 giving you a better resolution.
Due to a monitor being 16:10 and not 16:9 ratio
planning on buying a 19inch widescreen monitor next week for my 360. ive looked at loads of websites but im still really confused over the resolutions.
so to get the best picture (when my native res is 1440x900) what res should i set the 360 too in the dashboard? :confused:
Personally i recommend you ask in the monitor thread, bound to be others that have or know someone with a particular brand/model that works well with the console, sorry i cant offer more help though.
