Is one 360 rad enough for the below loop, i am running one atm and very happy with the performance, CPU tops out at 60deg no matter what i am doing.
GTX580 > GTX580 > CPU > RAD > RES > PUMP
I guess my tagen 700watt PSU is also just under the limit of doing all of the above as well, or just on it.
The case is a 700D and while i could put a good quality 120mm rad in quite easily i would prefer not to as i like the clean lines around the M/B so i guess it means hacking the bottom section to fit in a 240 then move the pump up or would a 120 be perfectly fine for the job.
p.s
Yes i want to play BF3 at 60 frames with all the sillyness turned on.
p.s
