360 to PC monitor cable...
silversurfer said:
It'll do that and more, I presume thats the offical one.
Cheers.
No idea, just need one to connect to my Acer 1916 (no DVI) as that's what am gonna run the 360 on.
Is there a switcher out there so i dont have to keep changing leads?
silversurfer said:
You mean the lead is fixed to the monitor. I think the offical lead comes with a gender bender :D You can just swap about then
Sorry, not sure what you mean.
I mean so i dont have to keep changing from PC to 360, is there a controller box out there?
Oh rite, yea I bet there is. I think ocuk also sell that
I just used an adaptor so I could switch cables quickly without having to undo either end.
I couldnt find it, buy do a google for kvm. I think thats what you want
Got the same set up sorted :)
laptop connected to KVM switch
xbox 360 connected to KVM switch
KVM connected to Acer AL1916w
works a treat :)
Any questions give me a shout.
cheerio
Ryan
Same; got this PC and my 360 through an Acer via a KVM switch. Even got a PS/2->USB adaptor off the 'bay so i can use my keyboard with the 360
(handy for writing messages).
works a treat :)
cheerio
Ryan
Hi Ryan, just the man.
This KVM, which product number do you use?
Also, i just want to switch between PC & 360. could you recommend one that does just that, and only that (as cash is tight)
Also with your Acer, the 360 on it looks washed out, what settings do you use on the monitor, and what res do you use on the 360?
Cheers.
Can anyone confirm that the gender bender comes with the official lead? :D
Have a spare CRT I want to use but it's cable isn't disconnectable at the monitor end.
yes the gender bender comes with the official lead
Ivan Drago said:
Just to check, although its listed as a HD cable, it will work on a none HD monitor won't it? (Belinea 102035W)
HD isn't some magical wonder feature on new montors, PC monitors have been capable of HD resolutions for over a decade :p, it's just pixel resolutions in progressive scan pictures.
The monitor will be fine, just you'll have to find the best resolution for the monitor by playing testing a couple of the 360 VGA resolutions.
;) Just wanted to be sure, plus i've just worked a 14 hour shift so brain is a bit groggy :)
