4 cases to choose from please help
28 Feb 2012
I just can't make my mind up . I want a case with good cooling and one that won't let much dust in , I hate dust . The case must fit a 7970 in it , these are the four cases I like .
Cooler Master CM-690 II Lite Dominator Case ( will 7970 fit )
Cm storm trooper
Cm haf x
Xigmatek Elysium Full Tower Case
If you have any of these cases please give me a quick reason to buy it , also if there is a better case for what I want please let me know
Thanks very much
Watercooling or Aircooling?
The only one I might rule out of that choice is the CM-690ii. The other three are all good solid cases.
If it were my money, hmm, I'd probably lean towards the Storm Trooper, or maybe the HAF X if you wanted watercooling.
Other alternatives are the Shinobi XL, the Switch 810, the Phantom, and if you could stretch to it, the Silverstone FT02 is the king of air cooling.
kd
Yeah, if you're only ever planning to go air cooled, I'd definitely stretch to the FT02. 7970 will fit though.
But yeah, if you don't need watercooling, out of your list I'd probably go for the CM Storm Trooper.
I admit there are some substantial differences between the FT02 and Storm Trooper aesthetics.
kd
Personally love the Stormtrooper it's pretty much a HAF X with different Fascia
But would you consider the Corsair 600T? it's excellent to cable manage and a pretty attractive case especially in White.
haf x out of the four, though , I would opt for Shinobi XL or 600T :)
I used Elysium for sr-2, not bad too but might be too big.
I had a look at the haf x in the showroom and didn't like the look of it , I went for the antec 1200 v3 and must say I'm very happy with it . Looks simple and cools very well .
Thanks for all your info
