Hi,
I have the HP Proliant 4 bay N54L with 4 2TB disks. It currently sits on top of my PC as a NAS / download box. Nothing intense, most of the time the load is 0.11, 0.15, 0.10 or lower unless I'm copying something big or it's backing up or whatever.
Despite changing the fans etc. it does of course make a bit of a noise.
Anyone know if it'd be OK in a wardrobe to block off the rest of the noise? The wardrobe doors just flap closed, no latch/handle or anything, so it's far from sealed. I'm just a little worried about heat build up over time?
Current temps are nice and cool (according to FreeNAS sysctl):
Thanks.
Code:
CPU temp :
dev.cpu.0.temperature: 33.0C
dev.cpu.1.temperature: 33.0C
HDD temp :
ada3 24C WD-WCAZA3585219 WDC
ada2 23C WD-WCC4MKJCDR4D WDC
ada1 24C WD-WCC4M7TELT9L WDC
ada0 22C S2H7J90B909357 SAMSUNG
da0 33C Z300JTT9 ST4000DM000-1F2168 - EXTERNAL BACKUP
Thanks.
