I tried once before but never got anywhere. Not really clued up. I read some guides but was still confused.That's more like it, now try some overclocking.
P95 crashed the pc. Might try real world with it at that and see how that goes. tried upping the volts a bit more 1.26, 1.27, 1.28 and had bsodReal life usage won't get as hot as P95 anyway so that should be fine, just check your temps while gaming. You may find that now you have upped the volts to 1.25v that you may be able to use a higher multiplier so once you are happy with it at 4.2Ghz try 4.3Ghz. Mine was stable across 42x/43x/44x once it got a vcore boost although it was a extra step above yours (1.275v).
Most places seemed to suggest 1.2v as a good starting point
This morning I went to 4ghz and upped Volts to 1.2 and bsod.
Dropped volts to 1.18 and ran Aida 64 for 1hr 30 and temps didn’t go above 61.
If I cant run with volts at 1.2 I don’t think I’m gunna be able to OC much more. I can try 4.2 at 1.18 and see how it goes.
As a rough guide the front and bottom fan positions should be set as intakes and the rear and top positions set as exhausts although in your setup that would mean you are exhausting a lot more than you are sucking in at the front. What case is that? I can't think of what one has a pair of 80mm rear fan positions these days.
