Hey all.
Picked up a 4770k cheap and trying achieve a moderate 4.3 - 4.5ghz OC, but Haswell is like molten lava;
@ All stock settings it hits 85(max) after 16 hours Prime95.
@ 4.5ghz, 1.25v (manual), under water (Corsair h80i) = Hits 98oc (?!?!?) after 5 mins of Prime95 blend.
I know a 120mm is not the biggest AIO but 98oC? With case open +next to an open window? Not even close to ideal temps.
@ 4.8ghz it actually boots +runs prime (albeit, for 2mins, before meltdown), so I'm confident it's worth the effort/money to OC.
Plans so far ...
1) Delid +Conductonaut
2) Replace h80i single fan with 2 x PWM Corsair ML120 120mm Premium Magnetic Levitation 2400rpm
3) Unload stress on IMC (replacing 4 x 4gb DIMMS with 2 x 8gb as below).
-Current = 1866mhz (cl9) Corsair Vengeance LP @ 1.5v
-New = 2400mhz (cl10) Mushkin Redline @ 1.65v (maybe try for cl7 1600mhz @ 1.5v?)
First all; PWM Questions...
How many PWM fans can I run off a 4pin cha-fan / CPU fan header?
My z87-k has 3 x 4pins (one used by CPU pump)...
Is it possible to have 2 fans sharing PWM with the cpu pump (using a 1 into 3 splitter), or is that unwise?
I really want to upgrade the h80i to push/pull config, so need them both running at same speed... At max I guess they will be crazy loud at - 2400rpm.
Will the fans still ramp up/down with CPU or case temps if plugged into...
a) 3 pin mobo headers?
b) 4pin to extra adapters (eg 'Y' cable? or 1x4pin into 5x4pin Hub)
few of them say "only one fan from the chain will return an RPM to the mobo"... Which i'm guessing it means they will just run at full speed?
Lastly - What would you guys expect a non lidded/delidded 4770k to get with a h80i? I should think 4.5ghz should be relatively easy on a £70 cooler, with good fans/airflow?
Many thanks guys
Plans so far ...
Many thanks guys
