- 29 Nov 2010
make sure you select the correct voltage not cpu vtt
your default should be somewhere around 1.200v bump it to around 1.290v
that should fix the black screen issue
if not you can always try bumping up the pci express from default auto to 101mhz aswell.
I couldn't find the option to bump up the voltage but set the pcie to 101mhz and while gaming instead of the screen turning black after 10 minutes the game started artifacting like crazy. Still don't know how to fix this though I'm gonna try and see if upping the voltage on the cores will help a bit but at the minute the oven trick is looking very tempting
