Adjust the transmit power to give you the RSSI figure you consider acceptable. As a courtesy to other WLAN operators, you should only use as much transmit power as you need.
I personally think -70dBi is about the limit of acceptable so I start off with everything at low power Tx and see what I get. Generally, low power Tx on 2.4GHz is plenty but I often need Medium Tx power for 5GHz.
I’ve yet to come across a phone or tablet that can Tx back to a UniFi access point at the limit of range when the Tx power is set to high on the access point. And that’s the issue. The access points can blast signal out which phones and tablets can hear, but when they send ACK signals back to the access point, the access point can’t generally hear them and no connection is made. So, if you feel you need more Tx power, you generally actually need another access point to improve coverage. Low and Medium Tx power also encourages phones and tablets to switch to stronger access points faster, which is what you want really.
