6 pin to 3 pin adapter anyone?
3 Apr 2017
Hi, I bought a Game Max Predator case, inside has a fan hub which are 6 pin fans (weird I know). I built the system now, but I still need another fan inside and I've used all the hub connections up. I'd rather not buy another hub for 1 fan, anyone know if you can get a 6 pin to 3 pin please so that it works through ARGB for Asus Aura? These are the fans:
https://www.ebay.co.uk/itm/Game-Max-Spectrum-Single-Ring-Rainbow-RGB-LED-120mm-12cm-PC-Case-Fan-6-Pin/312227577321?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
Thanks in advance.
Plenty of 5 pin to 3 pin adapters but can`t see any 6 pin to 3 pin
Thats the problem with proprietary fittings
looks like you will have to buy another hub and remember to get standard next time :)
Okay thank you for the help. I'll buy another hub and a splitter cable to get the job done :)
why not buy a different brand of fan ?
Or is it imperative that it matches the others in this case ?
If you don't want another hub you could always solder on a standard connecter yourself, obviously you'll void the warranty and it will involve some work, to find out what each wire does before you carry out the "surgery"
I'd like them all to match, I wouldn't usually but yeah it doesn't look that good with them being different fans mostly because the cooler master ones the RGB is in the middle, while the GameMax ones are around the edge and just looks kind of weird IMO. Soldering one myself, that's funny because I don't think I've ever seen one in real life haha
The hub supports up to 8 fans, which should be plenty for most systems.
PWM Hub – A PWM hub has been included allowing you to connect to 8 6pin fans and 2 3pin ARGB LED strips. From the hub you can control the LED speed, LED mode and fan speed.
