In that case you may get a bit more out of a 120Hz monitor but you have to have a long hard think whether responsiveness is all that important to you or whether the improvements in image quality of a non-TN panel may be a better choice for you. You did mention that you found gaming at 60Hz 'fine' but I suppose you won't have used PVA/IPS panels and 120Hz TN panels to compare? If you do want to 'unlock' as much performance as you can from your system I wouldn't go for the BenQ now when some new 120Hz monitors from Acer, Samsung and possibly others are just around the corner. Backlight bleedthrough effects any LCD monitor but the degree of this varies considerably. It is quite common for it to vary slightly between individual units of the same model, but in the case of BenQ's recent launches the inter-unit variability seems to be quite significant and greater than usual.
me want!
(the 27")
