I'm happy with my gigabyte 7970 windforce I hit 120fps in BF3 on high and between 60-80fps on ultra, and that's not much higher than stock at the moment!
1150mhz core is what I will probably use on a day to day basis.
Regards
Regards
,next question is did you enable vsync in the global profile or just in the wow profile ? If you just did it in the wow profile then all your other games may still be using adaptive vsync.Make sure you activate it in global profile ,but check any of your individual game profiles that you play to make sure it's using either the global setting you have selected or is set to on in the individual profile.
