- 28 Oct 2010
- South east
Hi
So i got my minidp to vga adapter today and i managed to get eyefinity working at the resolution i want (3840X1024)
The only problem is if i change the resolution or add bezel correction (i know its like the same thing) or even boot a game like dirt2 which refeshes the signal the dp monitor gets no signal until i restart.(ive tried replugging the dp to dp socket and ive turned off the monitor and turned it back on and ive unplugged and replugged the monitor none of these work.) So basically i added bezel correction, and the dp screen goes black and has no signal, i restarted and it works fine. I can live with this however with games like dirt2 where it refreshes the signal theres no way to sort it. I dont think the problem is with the adapter as it works at the res i want fine, i think its more of a card issue, what do you think? Driver problem? Bios problem?
Ill try anything within reason so even if you think your idea is silly please let me know
