Fit the clamp & have a look but if you blow the pipe off
That's my worst nightmare-turning the pump on and the tube blowing off![]()
I've realised that a 45' barb won't work, as the barb will go straight into my rad.
Looks like the kink and lose fit are due to the wall thickness of that tygon.
It's too soft for tight bends or 1/2 barbs without clamps
Any kinks are perminant damage in thin wall tygon - imho i'd redo that length of tubeing
Tygon is more elastic that pcv tube and you've got the thin wall type
Part number AAC00033 (7/16-5/8)
AAC00034 (7/16-11/16) is the one to get if you want 7/16 without clamps but it's not widely available.
7/16-5/8 in xspc, masterkleer or Primoflex are all fine with 1/2 barbs.
For a first loop buy two metres of masterkleer or coloured XSPC tube.
thin wall tygon is not beginner friendly.
I just had a look @ your build log and the pictures you just posted but I cant get a good look.
It maybe a better bet to do a new loop or run the pipe a different way.
If you remove the tissue & take some longer shots.
I also want to know whats happening at the bottom of the GPU to the rad.
Also will the tight 90 deg bends work?
but that for another thread.
