lol yeah, I figured that a flat heatspreader + heatsinks would work well enough. Just adding surface area in my warped logic
Besides, those flat ridged vram heatsinks from sapphire are just stuck onto the plate too.
The Alpenfohn thermal glue stuff is pretty much permanent from what I gather (EDIT: This turned out not to be true), so I spread a bit of TIM on the heatsinks and put a tiny dab of superglue in two corners.
Once they were fairly firm, I was able to clean the excess around the edges.
Those 92mm fans (Scythe Kama pwm 2450rpm) aren't the only fans at work here btw.
Cheers Greg
Cheers Greg
Just felt like splashing out and making my rig 'my own' if that makes sense.
