You need a better wallpaper that goes across all three.
That picture was taken the day I got them.
Just testing if everything worked OK at that point.
That's a very nice looking set-up there, Surveyor.
Could someone spec me 3 thin bezeld 27" monitors and 2 7970's please
If it's a good 750w you should be fine
My vote for monitors goes to Samsung S27A750D's, expensive but worth EVERY penny IMO.
Also, please do take into consideration, are 27" screens really the right size for you? They can be quite painful for gaming if you like to sit close to your monitors, whiplash and all that![]()
Yeah the vram will, especially with 3 27" monitors
Surveyor, what gfx card(s) you running?
Will my mobo bottleneck the 7970's
Im using a cm 690 ii lite, i have 2 exaughst fans, 1 at top and 1 at rear i also have 2 intakr fans 1 at front and 1 at side blowing over the gpu, should case be changed aswell to maybe a bigger full tower? Haf x etc?
Will the refrence design be ok for me then?t
If you're eventually planning on getting three 120Hz monitors then you should decide which of those you want so you can see how you're going to connect them to your graphics card(s).
Na i dont plan on having 120hz monitors, just standard 1080p 27" monitors with eyefinity
My first 7970 is coming from a local shop in the week
