- 1 Jan 2006
- Sheffield
Hi,
I've got a 8800 GTS 320mb arriving tomorrow, to replace my much loved but frankly rather lacking 7600GT.
Now, I'm a bit confused about power issues, 12v rails and what have you, and need some advice.
I currently use a 420w Xilence PSU with this written on its side:
+12v1 13A 156W
+12v2 14A 168W
I also have a 350w Hiper PSU that says the following:
+12V1 15A
+12V2 15A with max combine wattage of 300W
I initially used the Hiper but was not impressed with its stated 'inaudible' Low Noise feature... so I replaced it with the Xilence which is quite a lot quieter, but I'm not sure that the build quality is quite as good. Both have a dedicated PCI-Express connector.
So, which would you recommend for me to use? The Hiper obviously has lower watts, but it says it has higher amps on the 12Vs. Which is most important?
Or are they both crap and need replacing?
See my sig for other specs - I also have an 80gb, a 250gb, a DVDRW and a 3-port PCI Firewire card. It's all stuffed into a small but sturdy and cool running Chieftech case, just about deep enough to fit my 8800 into!
Any advice appreciated.
Ta
+12v1 13A 156W
+12v2 14A 168W
+12V1 15A
Ta
