8800 temps with HR-03-Plus
20 Aug 2005
Just wondering what temps you guys are getting? I have an MSI 8800 Ultra factory overclocked at 660/1512/1150, and I idle at 52C & after about 5 minutes on ATI tool, I get about 70c
Which fan do you have on it ? 70c sounds a tad high for that cooler with a decent fan.
My GTX (630/2000) idles at 51ºC and is at 67ºC after 10 minutes of ATI tool. That's with a 120mm 1600rpm scythe.
I don't know how normal that is as my card ran hot to begin with. It idled at 76+ºC with the stock cooler.
Mine idle's at about 51-53.
Load is around 80 I think.
That's a GTX OCed to 635/2000 with a 92mm fan on low (think it's ~800RPM).
Stock cooler was very hot:
Idled around 75.
High 80s, sometimes breaking 90 at load.
I'm sure the massive amount of thermal goop didn't help. :/
